ericlachance
171
About a month ago, I replaced the front master cylinder piston assembly and seals as It was leaking brake fluid. Last weekend, I went for a ride and everything was fine, brakes worked great. So today, I took my bike out to finish cleaning it, and suprise, the front brake was not working great. It slows down, but does not lock as it should when going slowly(walking pace). I went down the driveway with gravity, the bike wasn't even runing, applied the brakes, but not much happened. I checked the obvious, The master cylinder is still full and not leaking. Maby the simple green I use got onto the brake pads and glazed them? Did anyone ever hear of simple green doing that? What else could it be? Pads seem in good condition and are far from being worn out.
Any help is very appreciated
Eric
