I am having this problem, when i forget to turn the gas off while in storage, the almost all the gas from my tank drains into the pipe, my local shop said that a new NEEDLE VALVE SET should fix this. What do you think? That is a OEM 30.50 piece. also where can I buy new gaskets for the whole carb (kit). It is a Mikuni TM carb.
Thanks Chad
Thanks Chad
