ukracer
31
Hi guys i have a 04 rm 125
bike was jumping out of second gear under load
changed selector shaft (chipped) and worn selector fork
ok for a couple of seconds then had problems again
after another look selectoe pawls 1 and 2 had bad wear so replaced them too
now when changing from 1st to 2nd even when clean changed its like a neutral and then after a delay it jumps into gear.
everything else looks good so any advice please.
regards
ian
trial_07
Play with gravity
1,430
Could it be the spring which makes the shifter come back in middle position? Anyway check all springs and their positions.
I had a quite similar problem not long ago. It turned out to be a missing washer near the camshifter. Did you check the camshifter pins?
