And from my experience with racing street bikes, new clutches are typically fine switching from regular oil to synthetic... but if you switch to synthetic on a bike with old clutch parts, it will often times cause the clutch to slip.
Sorry to resurrect this thread - I ride with ridersean - the thing spews oil out the tranmission vent tube - regardless of what kind of oil is in the transmission, is this normal, and if it's not are there any known typical causes and/or fixes?
is he over filling it? what do you mean by spewing oil, does he have to add oil after every ride. i fill mine to top of glass and ive never seen any oil come out of it. unless he took the seat off and looked while riding it around or if hes using an air filter oil that isnt red how do u know where it came from. atf is red. are you sure its tranny oil, not too much air filter oil?
probably around 50-100ml leaks out of the breather tube on a normal ride - yesterday it seemed like it got bad during some steep stuff - no, it's not overfilled, I filled it myself to half way up the glass when level just before we left.
It is definately tranny oil because we took the breather off the airbox to verify.
thinking either there is a missing valve/shield or possibly too much crankcase pressure from a bad main seal?
that was my first thought too since the bike is a 92 and it's got lots of hours on it. We're planning on sending it to EG for a full meal deal at the end of the summer, so we'll know more then!
