147leeman said:Dex-
For the tires, I kept all of dirtrider mag. articles which showed real weights and went from that. There were some comparable tires w/ similar weights but I've had good luck with the M12/S12 combo. Some tires added 2 lbs over stock.
the aluminum body bolts and titanium bolts take prep and care.
- lightweight chains like the MRDL stretch, I'll go through a few in a season I figure. I was surprised to get a chain lighter than stock though.
- alum. clutch plates wear out faster and contaminate the tranny oil quicker than steels do. I change the oil after every riding day
What Dirt rider has Tire weights? Anyone know where I can get some of these stats or if someone has the article maybe they wouldnt mind looking up the weights on a 2 or 3 different tires.
What kind of prep and care is required for the aluminum and titanium bolts? I thought the Quadraalloy coating on the Mettec bolts was supposed to solve the Titanium weakness problems.
Was the MRDL chain the lightest out there I was considering running the RK GB520MXZ3 or the Regina 520 RX3 but hadnt really looked into the EK chains but they are also available to me.
How much faster do the aluminum plates wear out compared to steel.
Was the shorty silencer you used the Titanium FMF one?
Would the standard length R304 Pro Circuit Silencer give any weight savings? You know what is cool is Ricky's custom Carbon Fiber silencer on his RM.
And for things you missed.... do you have a Wiseco forged Clutch basket? I was going to get an aftermarket basket just because I had problems with the durability of the stock one on my 85 but the Wiseco one is also lighter than stock I have heard because it is forged. Also what about aftermarket rims and wheelsets are they lighter than stock?
