1994WR250Chad
- Mar 19, 2006
- 46
- 0
GOVERNOR Problem
1994 Yamaha wr 250 (2stroke)
I just replaced the Piston, cylinder and the Cylinder head. everything came apart and went back together as planned and by the book.
In the process of putting the head together, I learned that the "lever" that adjust the valve for the exhaust is called the "governor". :whoa: This Lever, is routed down into the crankcase".
When checking all to make sure things worked, the Governor puzzled me... :coocoo: . because I could move it fine with little pressure from my finger, but when I use the kick starter to move the piston and to verify the parts are not binding, I notice he "Lever"/Governor did not move with the movement of the piston? Unfortunately, I did not think to check how the "governor" was actuated before I took every thing apart. because all I had to do is remove :think: two bolts in the governor to complete the job.
my question is, does the Lever called the Governor move:
A) at speed
B) by combustion pressure
C) when in gear
D) with piston movement
E) :worship: Grace of God
F) :| Pure Freakin Magic
G) Other. (please Explain)
When I use the kick Starter, it does not trigger. If it is screwed up i will be faced with removing the crank case to find/repair the problem.
Please help If you have an idea what i am asking.
Thanks!!
Chad
A) at speed
C) when in gear
Thanks!!
Chad
