CylinderStay
- May 18, 2001
- 95
- 0
My '02 KX250 is a @&"#$% to start cold unless it has a brand new plug in it. Lets say a new plug is installed, I ride for a day then put the bike up for a week. The next time I try to start it, it will come to life for a moment, then die. If I change the plug, it will start right away. Otherwise, I can kick till my leg looks like Popeye's arm and it will not start. When I pull the plug it will be fouled. Last season I reworked the jetting as follows: -1 size on the main, -1 size in the needle, clip in the second position, -2 on the pilot. This was to smooth out a bad case of sputtering with the factory settings. The only other mod is a 13oz flywheel weight.
Once it's running and warm, you better hang on. But when it's cold and does not have a fresh plug, it's a real booger.
Calling all KX Technicians!!!
Dan
Dan
