sandflyz
71
is it jetted properly. Mine will start usually on first kick. If not, then the second or third for sure. try a new plug and make sure its gapped properly
jmorrow84
5
My two cents...
Put it in 5th gear, rock it back and forth for about 30 seconds to charge the cylinder. Give it a skosh of throttle, followed by a healthy boot.
Worked for every CR I ever swung a leg across.
Good luck.
Someone
865
I always tip my 05 YZ 250 over (and my old 01 YZ 250) and let some gas spill from the drain tube. Fires first kick every time.
ellandoh
dismount art student
2,958
dont know why that works but it works for every bike i ever owned and my cousins drag banshee that used to have to tow behind the jeep to start :nod:
Someone
865
After kicking my 01 100 times or so a guy walked up to me and gave me the tip. I don't even try to start my 05 without doing it since it works like a charm. :)
mx547
Ortho doc's wet dream
4,785
103
i use the tip over method on my cr too.
that's only when it's cold. if your bike is hard to start warm, you have other problems to deal with.
CRguyStan
154
This bike is shipped very rich on the low circuit from the factory, I would start by going one step leaner on the pilot jet, leaving the main stock with your location. Turn the air screw out about 3 turns.
1 kick the starter over slowly 3-4 times to charge the cylinder
2 kick the starter over slowly to get the piston up top
3 with about 1/16 - 1/8 throttle give a very hard kick
4 should start in 1-2 kicks
I would also try not using the choke with the richer jetting and AR location unless it is < 50 degrees
Stan
SQUIRLEYMOFO
310
Stan
Geez maybe it's not that bad takes 3-4 kicks. I was used to my KDX which always started in 2 or less.
mxneagle
320
Tip method works for me every time, lean the bike over and hold it there for about 5 sec. When you pick the bike back up fuel should drain out of the over flow hoses. The slowly kick the bike over about 10 times to get it good and primed (or you can put it in gear and rock it back & forth). Now give it a good boot. Mine always lights up on the first kick.
ellandoh
2,958
mx547 said:
you're kidding us, right?
uhh, i thought we were helping a guy out that was having trouble, looks like you thought the same , he just said 3-4 kicks :rotfl:
see ya next time squirrely :bang:
Jun 12, 2005
229
You guys can help me my bike takes forever to start but its getting pretty cold here. What would my first step be for the cold weather? I no i hafta change my air screw but which way should i turn it?
ellandoh
2,958
youll get more help doing a search for winter jetting, if you dont find what you need start a specific thread for your specifics
SQUIRLEYMOFO
310
I've messed with this bike probably 20 hours, but ridden it only about 4hrs. Jetting is about as good I can get it. I'm thinking of a JD kit or Keihin next. I seriously expect this thing to start within 2 kicks is that too much to ask? Hell I know guys with four strokes that start easier.....one of the reasons I bought a 2 stroke. Easier starting, cheap maintence etc.....Or let me put it this way I've had a KX and KDX in the past and they were both easy to start.
mx547
4,785
103
i've certainly never considered three to four kicks as being hard to start.
just get the keihin and be done with it.
the knock against four-strokes being hard to start is that they are often hard to start after a fall or stall, not when they are cold.
SQUIRLEYMOFO
310
If I were taller I could kick it all day.......but when your tired and short. I don't want a Kouba link just yet. So I guess I'll try the Keihin mod next thanks.
ellandoh
2,958
ohh man sorry squirrely, i quoted wrong guy , i was trying to quote the canadian :bang: ill go back and edit
