fatboy8
5
I cant seem to get my radiator shrouds to unscrew from the tank.(1988 cr 250) How do i remove them,just pull out the threaded inserts? Bolts turn but dont unscrew. Thanks for the help!!!!!!!
Fatboy8
va_yzrider
353
Spray some WD-40 or other lubricant on them and let it sit for 5-10 minutes. Then use a T wrench to get them loose. If you don't have a set of T wrenches, get some. They will make working on your bike a much more pleasant experience. Just be careful not to tighten bolts too tight.
fatboy8
5
I tried the wd-40 and have t-handles,still no luck. I have cut the radiator shroud off the tank,but the whole bolt and threaded insert are turning. apparently i tightened them too tight last time i put them on.(a couple years ago) Any more ideas??
Fatboy8
russ2400
9
yea, try bending the shroud out enough to get a screwdriver to wedge against the insert. If you use some good penetrating lube, this should work. Good luck.
