ThunderGoat
18
Im sure you have tried this, but tighten the big ass bolt in the middle of the steering area where forks clamp and might go away, or dont ride SUZUKI. Freinds dont let freinds ride Suzuki
muddy226
271
You could try stiffening the forks with the clickers, a bit more compression and rebound damping, or you could try dropping the back end a bit via the preload on the shock spring. Having said that, when I last had headshake problems all I had to do was add a bit of rebound damping to the shock and that cured it. Good luck with it, there will be an inexpensive answer.
FRESH VIDEO
