JimboBillyBob
- Apr 18, 2001
- 9
- 0
I have a strange problem with my 95 620 RXC.
My lights/electrical on the instrument cluster have stopped working for the most part. The only operational part of it is the left turn signal. No right turn signal, neutral light, gauge lights, high beam indicator or temp indicator (never seen that one on).
I have checked all of the connectors in the headlight area for corrosion and they all appear to be in great shape and making good contact. I have also checked the grounds and also the frame ground and they look good also.
Since most of the wiring runs through the control switches on the left bar, I took that apart looking for a short, corrosion and just plain dirty contacts and found some dirt (which I cleaned) but that was it. Once reassembled, the instrument cluster is still out and the headlight still doesn't work (when running of course). :(
Has anyone seen a similar problem? I'm stumped because the bike runs great.
Thanks,
JBB
Thanks,
JBB
