white knuckes
- Jul 19, 2004
- 36
- 0
Just picked up a 2000 KDX200. Disclaimer: the manual is on order.
Now, I found there was no throttle or clutch play from the prior owners setup. I added play for the throttle but then inspecting the carb area noticed there is no idle tapered slide adjustment screw.
So do you set idle speed at the twist throttle adjuster or am I totally out there? There is a idle air screw adjust near the air box side.
Help me brothers
Help me brothers
