Hi, long story short heres my situation:
The left tensioner bolt (the bolts that push the wheel back to tighten the chain) is broken. I've drilled it to about 5 mm into the subrame until I realized that theres not enough room for the power drill and/or the drill bits aren't long enough to drill the whole bolt out. Its just how the bolt is situated in the frame, the frame gets in the way of the drill. Dumb mistake on my part starting to drill the bolt out i guess :bang:
Any suggestions what I should do? I'll see if I can get some pics.
There was about 1 cm of the bolt sticking out before and i filed it down a bit to get some vice grips on there. I had the vice grips on real real tight but the bolt just wouldn't turn, and I did spray some WD-40 on the bolt.
