QuentinCR250
- May 15, 2005
- 71
- 0
Hi guys,
After a couple of hours ride other day during which the bike went fine I stopped for 5 mins before riding back to the car, on the trip back the bike coughed a few times just like the fuel tap was turned off even though the gas was still on, It was still rideable but ran rough, by the top of the hill it had mostly cleared and I thought I was back to normal.
On the next trip out I only got a couple of laps and the bike was running really rough, I suspected a carb problem so drained the bowl after this the bike ran even worse. I pulled the carb right off and opened it up but havn't found anything that looks out of the ordinary. I have checked the powervalve inspection hole and the valve is turning when the throttle is blipped, i also checked the reeds when I had the carb off and they looked fine.
On the last short test ride after having the bowl off, the bike ran smoother but seemed pretty gutless then half way through the lap it came right and was awesome for about 1 minute before losing power again.
Do you think this sounds like a carb problem? I have got it off at the moment and are going to give it a full strip down in the weekend. the bike is a 2001 CR250 which runs the Mikuni carb. Does anyone else have any other ideas I should check to eliminate any other possible problems? Thanks for any suggestions...
