i took out my reeds i need help identifying what kind of reeds and what kind is the reed valve someone please help i got a picture taken thanks its a 2000 kx 125
Still looks like a stock KX setup to me. Boyesen Pro Series is a dual stage setup. If they are Pro Series you will have a white epoxy reed below the carbon reed. Also Boyesen usually tells you to remove the stock reed stops which you have installed in the photo.
