Can anyone help?
I recently serviced the forks on sons 426,I did everything by the book, including measuring how far to move the leg up and down when first priming (sad or what?). I filled the fork oil to within 100 millimeters of the top knowing this measurment worked for the jumpy track we were going to.The bike was then left for 2 weeks until we were informed the venue had changed to a flat fast sandy track so I decided to remove another 30 mm of oil.When I removed the caps & springs I found 1 leg with no visible oil in it and the other with approximately 10cc visible over the top of the damper tube. Can anyone explain what happened? All the seals etc are fine with no leaks.
