I just installed all new clutch plates on my 2002 CR250.
Before the clutch plates were installed the adjuster on the clutch perch was all the way in and the adjuster in the cable was all the way out.
After installing the clutch plates my clutch lever had a lot of slack. I tried to take it all up with the adjuster in the perch but it wasn't enough. Since the adjuster in the cable was already all the way out, I had to make a spacer to take up the rest.
First of all, as the plates wear doesn't it create slack in the cable that needs to be taken up with the adjusters?? So when I install new plates I should have to re-shorten the adjusters to get the proper lever adjustment, correct? But what happened was the opposite. :eek:
Did I do something wrong? Please Help, I need to ride tomorrow and right now I have it Johnny rigged to get by. :uh:
