andre1357 said:okay were do u get a ohm meter and wat do u test with it.
Add checking the plug wire. Could be that simple. The kill switch wire is my first choice.Ol'89r said:You can purchase an ohm meter from any auto parts store and your service manual will give you the readings and how to check them. If you don't have a service manual you should get one.
You can also remove all of the electrical components and take them to your local dealer. Most dealers can check these for you.
Before you do that, check the obvious. Make sure all of the wire connections are connected and making good contact. Also disconnect your kill button.
