I have a brand new 2005 KDX 220. This weekend I'm doing all the new bike prep stuff and decided, based on the info provided by this forum, to put in a Weisco piston to avoid the possibility of the stock piston cracking and all the damage that could do.
Basic problem, I cannot get the KIPS shaft nut off, YES I am certain I observed the left hand thread, turning the nut clockwise to loosen. I am supporting the shaft by putting an awl through the hole drilled through the shaft, but the awl keeps bending. The flats on the shaft are not working as I do not have a wrench that fits it tightly enough. The nut is only supposed to be torqued to 74 inch pounds so I cannot understand why I cannot get it to break loose. I have tried liquid wrench, tapping on it, even a little bit of heat. Any suggestions would be very much appreciated.
