Hey there,
Wondering if anyone wants to start a dialog. I just rebuilt the motor on a 1972 Yamaha LT2 (97cc with 4800 miles) replacing the piston, ring(s). and clutch plates. I was able to come up with a new gasket set, so the head, base, and crankcase gaskets are also all brand new.
In general, I did not replace any bearings or seals. I re-used the piston bearing, pin and clips on the top end. I cleaned every part carefully with gasoline and re-assembled it to the best of my ability..
As far as the bottom end the only things I did not take apart were the transmission, kick start gear assembly, and the main crankshaft (together, these are the things that sit in the left hand side crankcase after it has been split).
I rebuilt it when it started making a high pitched whining noise from somewhere near the top end when getting into the power band. The first thing I noticed when disassembling was that one of the two rings was busted in several pieces, with several missing (hence my decision to split the case and get any stray metal pieces out). I also found the broken ends of a circlip in the motor. In the bottom was around a half teaspoon of sludge with a smattering of well ground metal dust.
The circlip ends were from the middle of the kickstart mechanism. The circlip was still in place, and seemed fairly secure, so I left it. It is not a high speed part.
Just so you know, I cleaned every spring and screw. I carefully scraped all the gasket surfaces clean and used Yamabond 4 to reassemble it. It runs now, but the same thing seems to have broke. It whines (read: screams a high pitched metal on metal sound) when it gets into the good part of the power band. It will run for hours at less than 4000 rpm, but try to have fun (i.e. do a donut or accelerate hard) and it makes the most horrendous noise. I'm pretty sure the ring 's broken and/or the top end bearing is gone.
FYI, I broke the engine in by riding it around the neighborhood for 30 miles or so, from gentle to low-mid power band. I didn't hear the noise until I took the bike out this last weekend and really got on it the first time. The first time I heard it I backed off right away, but it was the first day of a 5 day trip. I took the engine up to the power band about three times over the 5 days, each time, hearing a whine like a dentist drill on a blackboard. Yikes. But we had planned the vacation for a while (trail riding in Sequoia at 5000-8000 ft).
I have another Yam LT2 that is in great shape with 1821 miles on it and it happily likes the power band, and has pop and punch. My girlfriend got to ride it and I had to ride the broken one. I put about 100 miles on the broken motor in 5 days, all under 400 rpm, sigh.
Before I rebuild it again, what I'm looking for is some advice (and someone to talk to).
Here's what I think I did wrong.
0. Rode it when it was broke. Imagine trails thru sequoia groves and try not riding. Sigh. I had to. At least I'm honest! I never heard any "thunks" so I don't think anything fell into the transmission. But I sure didn't make the cylinder wall any better. I can pretty much peg when the whining noise will begin and could drive around all day at 3800 rpm without hearing it if I wanted.
1. Did not bore cylinder. The old piston was 1st oversize (.25 over). It had two rings. The new piston only had one ring, but was .25 over. These pistons are not extremely easy to come across, so I decided to use it up, without boring, rather than scare up a 2nd os set. The cylinder had some pretty bad damage, most notably a couple of vertical groves around the exhaust ports where the pieces of old ring had scraped it. These grooves (call it two) were approx 1mm wide and maybe .1 mm deep. I gently took some 600 paper to the walls by hand but didn't really take any material ... just shined them up and touched the edges of the ports slightly to try and micro-deburr them, if that makes any sense :-) When I put it together, turning it by hand, you could hear the oil and air sucking thru the grooves, but everything moved smoothly and it still had enough compression to start and run.
2. Did not repack the bearings. There is a question of whether or not I am capable of removing the crankshaft from the left side and/or splitting it to get at the big-end rod bearing. But I did flush it with gasoline and probably sucked some or most of the grease out of it and all the other bearings. I feel like an idiot, but I wanted to fess up. When I put it back together, I figured everything would be bathed in oil and as I may have mentioned before, I didn't want to mess with the bearings and seals. But I probably should have done what I could to repack them. Including the little end bearing which I just oiled as I was reassembling everything.
BTW, There's another noise that came up when I stressed the transmission, but I know what that is, I think. The clutch basket is held onto the main drive gear by three rivets. There was a little play in the basket when I examined it. I think that when it's stressed it moves a little out-of-plane making a crunching low pitched growl. It only happened once on the 5 day trip.
Status:
0. I have the shop parts book and service manual as well as a Kilmers for the bike. I have studied them extensively.
1. I found the only remaining NOS drive gear - clutch basket in the country and bought it.
2. I am getting new cylinder base and crankcase gaskets from Motogrid. Unfortunately I cannot find another copper head gasket so I plan on re-using the one thats there (that I just put on 3 weeks and 100 miles ago).
3. I have bought several NOS seal sets for the bike on ****. Any needed seals that are not in the set, I will purchase individually when I discover they're missing (when I get the sets and compare them to the parts book)..
4. I have bought NOS 1st os and 2nd os pistons and rings on ****
These each have two rings and are from "Rocky Manufacturing". They come with new pins and clips.
5. I have ordered all new bearings on Motogrid (including rod small and large end, crankshaft main bearings, both transmission shaft bearings. I've never ordered from Motogrid before so it could be weeks and/or I could find that some of them are unavailable. But right now I hope to get them all (over $100 worth of bearings).
Plan:
A. Tear the whole thing down again. Still don't know if I should or can remove the crankshaft from the left side case, and dissasembling the crank itself (to replace the big end bearing) scares the piss out of me. There are apparently special tools to (a) remove the crank, (b) take it apart, and (c) put it together. I can probably use a crank puller I have to get it off and apart, but it does'nt sound like I want to pound the halves back together with a hammer. Yamaha has a special tool that compresses the crankshaft halves back together. Advice on this would be helpful.
B. Replace (and pack) all bearings. Not looking forward to this part. I will probably get a heat gun, cuz I hear that's about the only way to get them in and out. Anyone with experience on replacing bearings on small cc engines can help out here. I imagine they have to be micro aligned when put back in, but is sounds like you almost need a sledghammer to put them in. I've never changed a bearing before. What I'm hoping is that someone will say"go ahead, it's really easy", and it will be and we'll all live hapilly ever after :-).
C. Replace all seals. I should be able to do this with my skill level.
If I can get to them (note above about left side main seal and bearing ... I don't know how to take the crankshaft out of the case).
D. Measure the pistons and the cylinder and make a determination using the shop guide and probably the 2nd os piston about what diamater to bore the cylinder out to.
E. Get the cylinder bored out. It's easy, I suppose, if you know where to go. I'll have to find someone from scratch to do the job. My local Yam dealers won't touch this old motor and I don't have a regular ongoing relationship with a machine shop. If anyone knows anyone around San Diego that they would have do this, PLEASE LET ME KNOW.
F. When I bore it out, I will probably worry about the change in the port sizes, but do nothing about it.
G. Get someone to mess with the head regarding the new bore size. At least to take the lip to the new diameter. Don't know about increasing the bowl size to adjust the compression ratio downward to compensate for new piston size. These seem like pretty specialized machining tasks and I wonder if I will have luck finding someone to do it.
H. Clean and install the oil pump. Note that I am currently pre-mixing this bike between 16 and 20-1. When I bought it, the guy gave me the oil pump and parts in a plastic bag. It looks fine and I think it probably does a better job of lubing the bottom end than mere premix (although with the leaky rings and high mix ratio, I'm pretty sure the crank got some lubrication). So I want to re-install it and test it as I put the bike back together.
I. Put it back together using the new clutch basket and now slightly used clutch plates I put in last time. They're working fine. Put as much grease on bearing surfaces as I can. Oil the sh*t out of everything else. Seal it all up so that not a drop of oil comes out.
J. Set the timing. Had a little problem with this last time. Manual says 1.8 mm btdc ... but I couldn't figure out how to hook up the ohm meter. Seems the coil or condenser was in-circut and messing up my readings, so I just eyeballed it. I'd like to get this right when I reassemble it. I had to way advance it to get the bike to run decently at 8000 ft. Now that I'm back at sea level it sounds like its pinging (pre-burning), esp at low rpm. But I don't think this has anything to do with the screeching noise in the power band.
So that's it. I know this is a long post. If nothing more I hope you enjoy reading it. Truly however, I'm hoping advice on the issues noted above and any other general comments or discussion would also be appreciated.
Thanks very much,
- Pat
Status:
Plan:
Thanks very much,
- Pat
