KTM wood spike
- Jan 2, 2000
- 8
- 0
I need a little remote diagnostic help here please. I have a ’84 XR350. I got it in boxes about a month ago. It had dropped a valve and destroyed the topend. I rebuilt it and it ran great for about two weeks. Saturday I was out trail riding with a couple friends and ran it out of gas. It just stalled--I turned the petcock to reserve and kicked and kicked. It still has not restarted. We got the truck and took it home.
Here are the troubleshooting steps I have taken so far.
Filled it up with gas, checked the spark plug, big and blue. Cleaned the carbs, the pilot was clogged so I thought I had found the problem, it still won’t start. I double-checked the valve tolerances and the manual decompression settings, they were all spot on. The auto decompression has been removed so that should not be the problem.
This is my first real problem with a 4 stroke so I am a little stumped. I have good compression, a big blue spark and gas is getting at least as far as the carbs. But it still won’t start.
Next I am going to pull the valve cover off and double check the cam and chain and make sure it is still set correctly. Can the cam chain actually slip on the cam sprocket?
It could be electronic problems but that would be a real coincidence since it happened after running out of gas.
What am I missing? Any suggestions will be greatly appreciated.
Scott
Scott
