Ok I smell alot of gas when idling, My bike has been popping on deceleration, 2 days ago I turned my Fuel Screw out a little because I thought that the popping was a lean condition, so I screwed it out some to richen the engine but that only seems to make the gas smell much worse,
so today I went out and I was at about 3/4 throttle and let off the gas and it did not start popping until the revs went way down, I did this a couple more times and it did the same thing,no popping until revs were down, Is this a Wrong Size Pilot Jet? I am about 600 feet above Sea Level,My mods are listed below-
Supertrapp IDS2 Exhaust-Uni Filter with 2 holes drilled in airbox and top cut out-bored .05mm over(its not much but dealer messed up when reboring my sleeve so they ordered that size for me). Thanks,Matt
