I just had the bottom end rebuilt on my KDX and put the first 130 miles on her two weekends ago. Last night while I was draining the oil, I noticed that the nut that holds the kickstarter on the spline was missing. :| I assume that they did not tighten or loctite it in when they rebuilt it and it simply vibrated loose and off on the trail. Anyways, the part # is 315G1200 and it appears to be a standard metric nut. Does anyone know the specs. so that I could replace it from the local hardware store and avoid ordering the OEM part? As easy as the bike starts and the minimal load bearing I assume that if I can match the size and thread pitch I'll be good to go. :ride:
Thanks in advance.
Thanks in advance.
