My 97 suzuki rm250 kickstart is jammed. there is no fluid in that part of the engine, what's wrong, how do i fix this, and can i do it myself. i thought with a 2 stroke you didn't have to add any oil besides mixing it with the gas
There is crank case oil to lubricate the tranny. Is the kick starter jammed or has the engine seized? If you can push start it then you may just have a bad gear in your kick start..........seeing that you have the transmission properly filled with oil.
