I have an 89 cr 250 that i bought at the end of last summer. Rode it some it seemed to run fine except it was really hard to get started.This year i started to do some research into the hard start so I removed the carb to look for dirt rust etc none found. While I had the carb off I decided to pull out the reeds and sure enough they had weakened and were not closed all the way. Well after replacing the reeds yesterday and putting it all back together the bike starts alot easier but it will not idle down.It runs about 4-5000 rpms and the only way to shut it off is to shut off the fuel and pull th spark plug wire.I pulled the carb back off and the slide and needle move freely and the rubber boot in front of the reeds is intact. Can someone give me some other things to check this is getting to be a pain. :clue:
