Hi/Lo bulb for stock headlight?
holmyj
56
Anyone know if theres a bulb that fits the stock headlight that has Hi and low beams? I mostly need it just to pass the dmv,not actual use. TIA
Makeshoes
No, I don't. However, Fredette has a "kit" that will do what you are asking. Makes the lights always on and runs the voltage through a resistor to make it a "low" beam (for short periods of time only), otherwise its on "high" beam. This kit uses your existing light switch. Hope this helps. :nod:
www.frpoffroad.com
