Hello everyone, I've always gotten good advice here, so I'm back for more!!
I did a compression test tonight on my 95 200. My compression was at 200 (with an automotive tester, is that OK?) at WOT. I assume it is from carbon build up on my piston and hopefully the cause of poor perfomance. It always runs good, there is just no punch or real power in the bike, although the low end torque is still good.
Am I going to do any damage running the bike right now??
My winter project is to rebuild the top end, FMF torque pipe, Boyesen Power Reeds (607), carb cleaning with new (42/45 pilot, R1174K jet needle, 152/155 main jet). Any other advice? I ride mostly woods 2nd-4th gear, at 1000 feet elevation in temperatures that range from 40 to 105 degrees!!! Any other advice/corrections??
Should I go ahead and just replace the piston (are they expensive??) and any cheap parts while I have it torn apart? This is my first rebuild, other than a ‘minimally standard’ tool set and a ring pliars thingy, do I need any other tools? Do I need to buy the piston puller??
Once again thanks in advance for any help
