A little while ago I made a "power now" (divider plate in intake side of carb, reduces to smaller venturi at low throttle=more torque.) for my DRZ and it worked really good at improving low end snap and just generally more torque. The real product is close to $100, so I made my own for free!
I make one for the 89 KDX (stock PWK36 carb) out of a clear piece of plastic, bit less than 2mm thick. It was pretty easy, hardest part was getting the curve just right so it would be snug in the throat. For that I traced the curve with a piece of wire, and transferred that same curve to the plastic piece. Cut some shallow grooves in the carb with a hacksaw blade, made a cutout for the slide, and tacked it in with JB Weld (ain't goin anywhere!)
I took it for a short spin around my yard, and I can tell you it did make a noticeable difference. It also made the jetting (pilot jet anyhow) rich, so I have to drop down to a 40/38pj from a 42 and I think it'll be perfect. I had a bog off idle, or more of a lack of power, but now it doesn't seem to have that! Definetly more low-end chuggability, should prove to be a good improvement in the trails, seems to be able to lift the front wheel a little easier. I have no idea how it affects top-end power, I doubt much if any. This weekend (or sooner) I'll be able to give it a GOOD test ride, see how noticeable it is.
I'll put some pics up in a little while. :thumb:
