Philip
Dirtweek Junkie
878
I borrowed my friends lens for the SX, hope to get some good shots.
LOU & Okie :nener: :nener: :nener:
CaptainObvious
Formally known as RV6Junkie
3,331
Nice lens. If you can't get photo's of the race, you could get pictures of the International Space Station with that thing.
Vic
***** freak.
4,008
Okiewan said:
What's up with those chicks?
The one at Detroit looked like she was suffering from MS or something.
Just stand there and hold the damn board please.
Man, you are old. :ohmy:
XRpredator
AssClown SuperPowers
13,504
I like a little wiggle with my 30-second board girl. What round was it? San Diego? Brunette, and she could shake it.
Philip
Dirtweek Junkie
878
I will have to go to my other lens for the girl, I could spot the lent in her navel with that thing. I usually get some good shots of practice and the qualifying. The main event last year proved difficult because I did not want to ruin anyones view. The lens size makes it hard to just throw up and shot(from your seat), You have to hold it steady and let the rider come into view or you get some blurry pics. Photoshop fixes lighting and color balance but doesn't do much for blur.I have a friend that works with track maintenance ( they do the tuff blocks) so I get to go on the floor for practice.
Philip
Dirtweek Junkie
878
Just because I can have cool toys doesn't mean I know what I am doing. I will pay more attention this year to what my settings are. Last year I just pointed & shot. I did get some good ones but will try better this year. Maybe you guru can help some. :moon:
TheGrinch
827
Okiewan said:
Blur? Witha 2.8? Dude, run that shutter speed up!
General rule - Run a shutter speed the same if not higher than the lens size to avoid camera shake e.g. 300mm lens = 1/500th sec.
Problem with shooting at f2.8 is lack of depth of field. If your focus point is not accurate you still risk taking a blurry shot. Best bet is to focus on a point on the track. Then pan the camera to follow the rider and release the shutter as he reaches the point you pre focused on. Also I suggest using a high speed film at indoor events at night e.g. 800/1000 iso.
A monopod/tripod would definitely help reduce camera shake, but might be difficult to get into the stadium.
Patman
Pantless Wonder
XRpredator said:
I bet a strobe light would help.
Maybe, but chances are you or those around you with strobe envy would turn in to a bunch of little pouty lipped 2 years olds.
Okiewan
Admin
2,239
Texas
The 2.8 will allow faster shutter speeds with lower ISO in less than optimal light...
No idea how the lighting is in there so I'd suggest setting ISO to 400 to start, put the camera in Av mode, set the apature to 2.8 ... focus somewhere on the track that has common lighting, see what the shutter speed says... like Grinch said, it needs to be at least the focal length of your lens. As long as you can get 500 or better, you should be okay. At 500, you will still get some movement in the image, some find this desirable (blurry spoke/knobs). But... I always get more keepers at 800+
Considering that the other side of the stadium is pretty far, you can probably get good DOF shots at 7.1 with that 300mm (guessing).
If you are shooting across the stadium (typical from the seats) you WANT the shallow depth of field, otherwise the bike/rider will just blend into the crowd on the other side of the stadium. Yes, focus is more critical. Make sure the camera's auto focus is servo mode and make sure the rider fills most of the frame, you should be good.
All that being said, just read about someone having to sneak a lens into Detroit as the rule was no more than 50mm in the stands. FYI. I'll be trying to get my 200 into Dallas, that plus the 1.4x should reach out to our side of the track, from the 17th row. We'll see.
Chili is probably the best moto shooter on this board, hopefully he'll see this and correct my statements :p
Kawidude
D'oh!
1,386
You can also try using the shutter priority mode on your camera (usually the "S" mode). If you run this you can crank your film speed up to even 1600 if you want. When you're allowing that much light in, with the aperature wide open (f2.8) you can really crank the shutter speed up high and stop the action nicely. In the shutter priority mode you can toggle the shutter speed around and the aperature will adjust accordingly. You'll see where your aperature ends up before you take the shot, so you can dial in how much depth of field you want. At 1600 iso your shots will get a little grainy if you try to enlarge them too much. So 800-1000 iso might be your best bet. But hey, with digital, just give it all a try!
Kawidude
D'oh!
1,386
Okiewan said:
No way am I using 800-1000 unless it's damn near dark :) Way too grainy, even with the good dslr's.
On higher-end cameras.. shutter priority mode = Tv by the way.
But yes... it's it've dark and fast action, using ISO 1000 or even 3500 on some DSLR's is your only option.
I should have added that I typically shoot with a Fuji FinePix S2 Pro, which is a high-end camera, and it seems to work well for me. I shoot a lot of sports candids for my studio and I can get away with iso 1600 when I'm in a gym that isn't very well lit. For outdoor stuff with nice, daytime lighting I won't go any higher than 800. Like I said before though, with digital you can just do a lot of bracketing and see what you like the best. Shoot at all possible settings and see what you really like!
Philip
Dirtweek Junkie
878
Thanks guys you've been helpful. I post some for judging when I return. :cool: :cool:
Chili
Apr 9, 2002
8,062
17
Based on the lighting at St. Louis you'll likely be unable to go below ISO800 at 2.8 to keep your shutter speed at about 400 which will still see a bit of motion blur depending on the type of shot. Okie to use the 1.4 you're very likely going to need to be at ISO1600 since the 1.4 costs you one stop doesn't it? Philip if you are on the floor for practice firstly I envy you and secondly borrowing his flash would be a huge help to your results and give you more flexibility on setup. On the floor I'd likely not even bother with the 300 as I'd likely have 2 bodies, 1 with a 70-200 and one with a 24-70 on it. Have fun fellas.
