how can tell the differnce between a 200 and a 220 carb??
kdx220freak
Registered
Aug 23, 2005
321
hi, im going to be rejetting my bike cause it is way off. I have a 220 but alot of people say that the jetting sounds like a carb from the 200. What are the differnces, how can i tell them apart?? thanks
Green Hornet
837
What is the jetting setup? Numbers Please
This is the STOCK JETTING CONFIG:
220-42 Pilot, 1173 Needle, 145 or 148 Main
200- 48 Pilot, 1174 Needle, 160 Main
What u got??
This is Canadian Dave's Recommendations:
1995 to 2003 KDX200
Stock -Run the stock R1174K jet needle in the second from the top clip position, 45 pilot jet, 155 main jet and fine-tune the pilot circuit using the air screw.
With a performance pipe/expansion chamber, the air box lid removed and the stock or a performance silencer run a 42/45 pilot, R1174K jet needle in the mid clip position, a 152/155 main jet fine tune the pilot circuit using the air screw.
1997 to 2003 KDX220
Stock run a 42 pilot jet,the stock R1173L jet needle in the second from the top clip position, a 142/145 main jet and fine tune the pilot circuit using the air screw.
With a performance pipe/expansion chamber, air box mods , the factory or after-market silencer and the stock 33mm carburetor run a 42 pilot, the stock R1173L jet needle in the second from the top clip position, a 145/148 main jet and fine tune the pilot circuit using the air screw.
Same as above but with your carburetor bored between 35 and 36mm or running a 1988 to 2003 KDX200 35mm carb jet according to 95 to 2003 KDX200 requirements.
Addition of Boyesen reeds or a Boyesen RAD Valve will require you to lean the pilot and main jet one size and readjust your air screw.
Green Hornet
837
kdx220freak said:
my main jet is a 155 and my pilot is a 48, how is this right if i have a 220?
Either a 35mm carb, is installed, It's a 200 instead of a 220 and/or the jetting is off.
The pilot should be around a 45, 42 or maybe a 40.
First figure the above out first
Get the CARB ID #'s and look them up in the manual or post them
kdx220freak
Registered
Aug 23, 2005
321
the only numbers that i could find on the carb, were
PWK
V981 A015
thats all i found it was on the side, right above the bowl.
kdx220freak
Registered
Aug 23, 2005
321
greenhornet, is there a way you know that is a kdx220 carb and not a kdx200 carb?? cause i measured it out to be 35mm but i cant see any evedence that it has been bored out.
Green Hornet
837
If it was indeed BORED and you are sure it measured 35mm. Then leave the 155 alone for now and change that 48 pilot out to a 45 or 42, possibly a 40. I'm around 500ft above sea level and have mine set up as 40, 152 and the 1173 in the middle or 2nd from top. I posted the CD recommendations. So try those
