Hi guys,
I am trying to install the flywheel on my Honda CR 125 2002 and it doesn't go fully on the crankshaft. You can see in the photo that it still could go about 1mm deeper. However, I tried to heat the flywheel and freeze the crank and it didn't help. I also tried to install it deeper by tightening flywheel nut but it didn't work either. Although I don't remember how it was installed before disassebling. The crank and flywheel are both Honda OEM.
Should I just leave it or something is wrong? How is it on your bikes?
