how do i set the timing on my CR500
mrbigal81
63
i just bought a 1989 CR500R. i don't know much about 2 cycles and im having troubles with it. it runs great but its really hard to get started. i read that the timing may need adjustment. how do i set the timing and do i need any special tools to do it? or do you have any other suggestions on hot to start the bike?
Thanks,
Alan Schulze
fatty_k
1,274
It could be many things that are making it hard to start. For one, I would check the reeds and see if they are warped or chiped. I have heard that chipped or damaged reeds can make a bike very difficult to start.
Papakeith
COTT Champ Emeritus
6,700
54
RI
If the bike "runs great" I would think the timing is ok. It could just take a while to learn the technique of starting a 500.
Here's what I do:
  • lean bike to side until fuel runs out of the overflow
  • set choke on - no throttle
  • kick through the stroke easy once or twice
  • Kick with some energy!
If everything is fresh (fuel,plug, filter) this will usually get me going.
mrbigal81
63
well i guess the bike isnt running as great as i thought. i let a mechanic look at it today and he said that it needed new reeds and new gaskets for the carb.
