My son has a KX100 and I got some new wheels for it. The sprockets bolts are not what I expected.
The normal bike wheel (eg, KX250) uses a bolt through the sprocket - and then through the hub - and then into a washer and nut.
The KX85 and KX100 use a double-threaded bolt. Think of a bolt with threads on one half, then a smooth portion (1/4") in the middle, and then more threads on the other end.
Half of this bolt threads into the hub. Then the sprocket is placed onto the bolts and a nut is threaded on from the front of the sprocket.
I'm unsure that I know how to get the proper torque on the bolt when I thread it into the hub. There's really nothing to grab onto to get any kind of torque.
Should I thread the bolts into the hub by hand as far as possible - then put on the sprocket and start tightening the nuts. When I torque the nut to the right spec will that automatically set the bolt into the hub properly?
The service manual is no help. I plan to use red loctite on the hub side of the bolt and blue on the nut side.
Thanks! Mark
Thanks! Mark
