how do you clean stained # plates?????
kawakid
39
I just got a new 04 yzf250, and its great, but after every ride the side panels, and number plates, or just any white plastic get dirtier and dirtier, even after washing it. I have tried soaps, and water, with hard scrubbing but it still wont come out. Is there any cheap cleaner or way to get them looking new again???????/ thanks
Smit-Dog
4,704
It's going to be a recurring problem, but you can get them super bright again using Soft Scrub and elbow grease.
Soft Scrub is kind of a gritty paste, with bleach in it. Use rubber gloves. Lay your plastic flat, apply Soft Scrub, and scrub the paste all over the plastic with a dense sponge. Let it sit for 5 minutes. Scrub again, then rinse. Sparkling white after that.
James
Lifetime Sponsor
1,839
Buffing/polishing compound (auto) works very well. I get the white paste looking stuff and use it on all of the plastic. Won't give that shiny new plastic look, but cleans real well and softens the scratches. I sometimes follow with armor all or similar if the bike is going to sit for a while.
darringer
1,029
Soft Scrub or even regular kitchen cleanser applied to a sponge works well.
ben.handasyde
62
use engine degreaser and let it sit for a few minutes then srub of with a brush paying close attention to the scratches. then cover with clear protective sheets or preprinted numbers. when it comes time to sell take them off it you want and bang they look good as new.
MikeT
4,095
11
Mr. Clean Magic Eraser. It works fantastic!. It will take a little shine away but much less than all the other methods shown above. All you do is add water to what looks like a chalk board eraser and rub a little, give it a try.
Sandy Whoops
74
Try car wax, especially 1 billed as a cleaner / wax. I disagree with the use of any abrasives - the small scratches left behind will trap additional dirt on subsequent rides.
For the pinger crowd, cleaner / wax is deadly on rear fender spooge. Takes it right off, even when it appears that the spooge has saturated into the plastic.
01KX250Rider
13
White Side plastics
After getting the number plates clean or replaced i always buy that clear plastic to go over the plate and under the number itself...when the clear plastic turns too dirty or fades just peel it off and look at your "new" white plastic again ! :cool:
Joe_148
54
what about black scuffs? I have black boot and tend to lift my feet off in the air and somehow always get big linear scuffs on my plates that are hard to remove
b dawg 311
Comet with a bit of water on the white and only WHITE plastics and some steel wool works absolute wonders on white plastic, and white plastic only. May require some elbow work but other then that thats all.
Brandon
