how do you get the sticky stuff of graphics
hapanese
Stuff is good
69
Try never-dull. It takes sticky stuff off of almost any surface. If using it on plastic, wipe it off immediately.
Jeff Gilbert
2,963
WD-40
Then clean with glass cleaner to cut the residue
MBFTY
Uhhh...
May 4, 2001
192
Goof-Off
I use Goof-Off! for removing the garbage left from stickers. You can get it at Wal-Mart for about a dollar a can.
It smells something awful, but it liquifys the glue, and it wipes right off.
I hear they are making a water based version now that doesnt smell as bad, but I have yet to find it.
YoTRacer158
312
ive had good results with staring fluid and gas...just make sure you wipe them down with contact cleaner to get all the residue off before you put new graphics on
CAL
2,032
I either do like Jeff and use WD-40 and then glass cleaner, or Desolve-it and then glass cleaner. Desolve-it works pretty well.
YoTRacer158
312
mtngoat...ive never heard of goof-off. what is it and where do you get it?
mtngoat
314
Should find it at your local hardware store. Not Home Depot, but I've seen it at Ace and the post above says Walmart too. Don't know what it is, but after trying all kinds of stuff, it works best.
