Ok, my KX has a nasty little gouge on the gas tank from the pipe mount rubbing into it. (Was a basket case, it was like that when I got it.) I repaired it once using a metallic epoxy putty that Ive had great luck with elsewhere. It failed. Leaked, then the whole thing peeled off. Then I tried with a marine grade putty that said it was suitable for fuel tank repairs, even underwater!!! THat lasted about 3 days before it to failed. The actual "hole" is more of a slot, about 2 inches long total, not more than 1/8 inch wide at the widest. ANy ideas about what I can plug it with that gas will not defeat? I was thinking good old JB weld next, but Im not sure.....
Thanks,
Neil
Thanks,
Neil
