jaguar
I tell you, sometimes its best not to be too cautious. Assembling my engine I let the snap ring fall into the crankcase because it fell from my hand while I was using the same hand to place a napkin on top of the crankcase opening. If I hadn't wanted to place the napkin there then it wouldn't of happened. But maybe it is a good thing because now I can tell you how easy it is to retrieve it.
I just dabbed some heavy grease on the crank and slowly turned it and the pin came up stuck to the grease.
I fell dumb and smart at the same time!
