HiG4s
1,308
I was at the track Tuesday and after going over a jump the clutch lever had no tension. I thought I brok a clutch cable but when I got back to the truck I found the lever going into the case had no tension on it. I have the shop manual for my bike but I can't find where it shows how to get to the actuating rod, cam or whatever is in there. Do you have to split the case? Or what? Has anyone else had this problem on a 125 Husky?
Thanks.
SPD
591
Double check the the cable. Had the same problem with mine last year. 12 mi from the truck, new riders that didn't know the way back. The cable had 2 wires holding it. The rod is on the right side. Very easy to get to.
HiG4s
1,308
Are you saying that from the lever on the left side of the case where the cable from the handlebar attaches, there is a cable inside going through the case to the clutch on the right side?
