blgrassick
- Apr 24, 2004
- 7
- 0
I have a 2004 husky CR250 which has 45mm marzocchi forks and sachs shock. I'm approx. 200ib and I'm finding the suspension too soft. I mainly race B- Grade motocross.
stock spring rates are :
Forks- 0.45kg/mm
Shock- 5.2kg/mm
The forks are the main problem so I had them revalved by the local dealer. They changed the midvalve a lot, from a single tapered section to a large tapered section on top of a single tapered section. They also said to use 5wt oil instead of the stock 7.5wt oil. This hardly made any difference at all. I also noticed that there is a lot of clearance around the damper rod, is this normal, or should it be sealed better like the KYB forks. Any info would be great.
Thanks.
Forks- 0.45kg/mm
Shock- 5.2kg/mm
Thanks.
