I have a few questions regarding my 2000 Yz 125.
1.What is the nozzle that comes out of the top of the case, below the carberator? It leaks fluid sometimes.
2. What would cause the exhaust valve cover to leak black oil? A bad gasket. It comes out of the top of the cover.
3. I was riding the other day and it was running real good. Then after about 3 hrs. of riding, it started not hitting the topend and not getting into high rpms. It was rela flat on the top. So i get of the bike check it out only to find the spark plug out about 2 turns. So i screw it back in and try her out. Still the samw. So i put another in, but this one is not new it was used but i cleaned it up. Still it rann the same. I will try a new plug but could anything else be wrong?
4. Is there another oil for teh transmission, like a car oil. i use Belray 75w. I would like other options so i can go by a local car shop like autozone insted of the dealer.
5.Do you guys set your float bowl level? Is it reallya necesstiy.
6. Where can i ordder jets at? I have serched and i found carbparts.com and and another website. But i cant find the jets for my carb.
7. Besides the dealer wherecan i get parts such as the plastic brakets that hold the brake line on teh swing arm?
Thanks, sorry for all the questions.
