- Nov 13, 2001
- 1,178
- 0
- Thread starter
- #26
whyz, your CF is around .97, all you got to do is multiply .97 by the size of your pilot jet and also do the same for the main jet (Example: .97 x size of the jet = jet size close to what you should run). Also in my manual it says to run the needle clip in the stock groove, and also turn the air screw 1/2 turn out from stock. Hope this helps.
