Jasle
- Nov 27, 2001
- 1,358
- 0
Just wondering if anyone has used this iCAT. there website is here
and it says this:
The iCat is an advanced electronics device which uses complex circuitry to change the shape of the ignition spark. The iCat can be fitted to most popular 2-stroke single cylinder machines in under 5 minutes.
The iCAT electronically alters the shape and speed of the electrical pulse, which produces the discharge spark at the spark plug. The new spark profile enables a much more complete combustion of the fuel/air mix in the cylinder during the ignition cycle optimising the total energy available. The fact that better combustion takes place means that all the fuel's energy generated in the engine is used to provide energy into the Bikes power train.
There is virtually no waste dissipated in the exhaust system. This results in instantly noticeable THROTTLE RESPONSE!
When looking at it it appears to insert in the plug wire. No descrtiption of the electronics it just says complex electronics...
Guess I'd have to see this one work before plopping down the $225
and it says this:
