canyncarvr
- Oct 14, 1999
- 4,005
- 0
Wondering, 'WHAT is the condition of my fork sliders (bushings)? Should I replace them next fork service? ...or not?'
You can put this under the heading of 'Completely Anecdotal Info' (and therefore, yes...of little use).
I don't keep excellent records as some do of bike hours. I know it's four years old, and it's been ridden a whole lot, about ten Dunlops worth, a couple of top-ends. How's that?
I figured the sliders had to be pretty much worn out. No particular slop in the forks, but with a fork oil change scheduled for this past weekend it seemed a good time to replace the seals and the sliders.
I found the sliders to be pretty much perfect in appearance. There was NO instance of the teflon coating being worn thru, scraped or otherwise boogered. It is a rather thick coating as opposed to what looks like a flashed plating I've seen on Honda sliders.
Unfortunately, they get pretty much beat to death in the disassembly process. Don't take your forks apart just to inspect them! You will probably need to put new ones back in.
There. Don't you feel better, now? ;)
