rcpilot_971
I have a 2002 CR250 with a FMF fatty and v force reeds other than that its stock stock I run vp 110 at 40:1 at about 400ft ELV dose any one know where a good starting point would be for getting this thing jetted
Thanks Tim
soulmate33
158
My '02 CR250 has:
My 38mm PWK has a 48 pilot and 180 main.
I'm at sea level here in Hawaii. At 2.75 turns out it is still a little rich.
I'm gonna drop to a 45 pilot and 175 main. Stock needle (for a 2000 CR250).
soulmate33
158
rcpilot_971 said:
is it rich through out or just on the top end
Both....I actually don't mind running it slightly richer, the motor runs cooler and hopefully won't have to worry about seizing the motor leaning out.I'm still running the same plug from last year.knock, knock on wood......
D36-108A
367
175 main, 45 pilot, DGK needle with its clip in the middle position, adjust airscrew to suit. BraaaaaaAAAAAP! Crisp, clean-running power from just above seal level to above 5,000 feet. Pump gas isn't a problem but I prefer to run race gas, and I put many hours on a single plug. Easy starting, never fouled a plug, blah blah, rave, rave.
t300
2004 cr250 jetting
2004 cr250r other mods, fmf fatty , fmf q-stealth, v-force 3, boysen exaust flange, keihn pwk 38mm of of a 05 yz250
stock cylinder pwk conversion
pilot - 42
needle - cej 3rd
main - 175
now running
terry varner modified cylinder and head
pilot - 40
needle - cej 3rd
main - 175
110 leaded race gas 50/50 with 92 premium gas
bike is a rocket.....
CR3999
163
JD jetting has or did have some nice needles with there jetting kits that are sweet. Try jdjetting.com .
