canyncarvr
- Oct 14, 1999
- 4,005
- 0
re: I don't understand the problem with...
I guess you could call it a trade off. The more oil run, the more power made...air/fuel jetting corrected. No argument..it's a fact. There was a white paper published some time back by McCullough in that regard. Up to the point the test engines wouldn't run due to oil fouling, the more oil in the premix...the more power they made.
Piston-to-cylinder sealing is important in a 2-smoke engine is the basic why of that.
While you may make more power with more oil...you also need a larger volume of that mix air/fuel wise. You gotta have the gas part, too! At some point you will want to do something other than: 1. Ride in a blue fog, and 2. Ride farther than ten miles before you have to go back to your rig to refuel.
Oil/lubrication requirements vary depending on the engine...and the oil. Super-M is indeed a blend. Maxima's req is 40:1 for a 200cc engine. Besides that, following is a quote that says Super-M is absolutely the best oil in the world:
..so don't argue with me about that either.
If you like SuperSyn at 452:1...I'm happy for you.
Anyway...as with most things the most important word is 'balance.' A balance between required lubrication, available power and miles-per-tank 'fer instance. It is possible (according to my bike, anyway) to have NO drips (spooge), very little smoke, plenty of power with smooth throttle response/transitions throughout and to run the same spark plug for over a year.
Stock needle clip position is #3.
If you're happy with an oem needle, a 160 main and don't want to mess with the pilot...you would be much happier if your bike was correctly jetted.
BTW....regarding 220s and smaller carbs. The two bikes (200/220) don't jet even close to the same.
From the original question I would infer that you haven't looked at the link noted in the 'Every kdx rider should read..' thread stickied to the top of this forum? CDave has excellent information to get you started in the right direction jetting-wise with various modifications.
Привет от Super-M ×. Хотите убрать эти приветствия? (з сюда писать ответ, только не забудьте об этикете) Некогда! Вырубай срочно! настроить...
