I have an 01 CR250, this sort of question has probaly been asked
several times but the search was to no avail. I have a V-force and just purchased an FMF fatty pipe. I just drove back from Florence oregon where I was riding the dunes. Everything was ok for the first day but then the bike turned lean. The plug was white as the day got later. I looked at FMF's specs for jetting and I even went richer on the main one and one clip on the needle. It would seem
that the temp of 50-65 degrees and a relative humidity of 70% would make the bike run rich. I also have an S-7 nozzle which may be part of the problem I am not sure.
I just can't figure out how it was running so lean if I am jetting with specs from So Cal at 70 degrees, sea level, and 0% humidity.
Any of you jetting gurus shed some light on what may have happened?
