Just a suggestion to those that are new to jetting their carbs. I HATE!!!!!!! jetting, I get a headache and often miss days of work due to stress related illness just thinking about it. Actually doing it causes uncontrollable eye twitching and nausea coupled with a deep depression and crankiness. A trip to the dentist is a viable option to jetting on my scale of enjoyable things to do. The problem is, If your not doing it your missing out. My new ride is a 2002 KDX200 and I've gone the route of the gnarly torque pipe and turbine core silencer, boyeson reeds and twin air filter with air box mods. I ordered up a good selection of brass and took off to a large open area to get the beast sorted out. (Heres the tip) DO NOT TAKE JETTING RECOMENDATIONS AS FACT!!! They may be a great place to start but ALWAYS check the results. I installed what was recomended to me (155 main/45 pilot) and the first plug reading at WOT was whiter than the plug came out of the box with a corresponding dead duck hole in the throttle response off bottom. Guess where I ended up a dozen plugs later....... The stock jetting with a clip position leaner on the needle and I'm not sure that was necessary. All told the biggest gain came from playing with the air screw for an hour. I now have enough brass to make a pretty neat necklace and enough needles laying around to make me look like an amateur accupuncturest and I'm running around with what Kawasaki originally intended. Go figure. The good thing is now that I've had so many WRONG jets in the thing and felt the results, I pretty well know a jetting problem when I see/feel it. Maybe that would be a good jetting lesson huh? Take a perfectly well jetted bike and keep screwing jets into it to see the results. ;)
Opinions vary
just my 2 cents
Opinions vary
just my 2 cents
