hi , i just picked up this 83 xl250r and i've been trying to get it running right , i've cleaned out the carb (3times to be sure) , it has the stock jets , they're clean as new , the float isn't adjustable in these 83's so i'm sure thats where it should be . the bike starts up first kick and revs just fine and has plenty of power , but when you rev it up and try to let it go back down to idle it hangs up . if you let it sit for a while the rpm's will drop back down to normal . sometimes it does it worse , sometimes it barely does it , but it seems to always do it a little . i got a new air filter and that solved the problem with not being able to cut the throttle wide open quickly . and i bought a can of starting fluid so i could see if the carb boot is leaking .... it's not . it's running hot too , so hot that it just dieseled after i turned the bike off . does anyone know the factory position of the mixture screw ? this is driving me crazy , i'll be sitting there and the idle will be fine , i'll blip the throttle and it'll rev up and then continue to hold higher rpm's after i let go of the throttle , sometimes it'll come back down , sometimes it'll just stay revved up . when i mess with the idle screw it'll come back down , but then i'm idling really low , almost to the point of it konking out . i've tried different positions of the mixture screw and it doesn't seem to change much , if any of you guys know what i should check please help me out .
