This thing is everything you guys said it would be. I've got lots of low end with the "gnarly" pipe. What kind of oil (pre-mix) do you recommend? What about case oil? I can't wait to get this thing on the trails!
everyone will suggest diff oils so you will have decide for yourself. personally i use pro honda synthetic pre-mix at a ratio of 40:1. And for the gears i use valvoline 10w30, which is what kawasaki recommends. Congrats on your new bike, you wont be dissapointed.
Congrat's on the new bike! I run either synthetic(50:1) or semi synthetic(45:1) oils in my bikes - pick one and stick with it. What did the previous owner use in it? What does your local shop carry? I don't think there is that much difference between the "name brand" manufactures providing they are the same type(mineral,semi or full synthetic).
Look forward to hitting the trails @ Muenster!! :thumb:
