kamchuka
50
from the four stroke dark side..... there are some things i miss. to compesate i have installed a steahly fly weight. oh by the way 01 rm250. and set my supension to the woods.
my ? is this:
im having a bit of trouble now on the gnarly hill climbs. i either was too stupid to notice it before, or the four stroke was that much better.........both im thinkin :nod:
the power band seems all over the place and i cant keep the thing on the darn trail.
any suggestions on getting this thing to track a little better.
i've only putted around the yard today to see how the weight works didnt seem a whole lot different, but we'll see on the trail.
p.s. its good to be back on a two smoker
showtime586
512
It will take some getting use to, but you'll be able to get it dialed in. The one thing that I will say is that even when you get it dialed in, you'll find that the thumper was an easier bike to ride. Not more fun, but easier to ride.
I still find myself trying to kick my smoker like I did my old thumper, but I don't worry about grenading an engine anymore either.
kamchuka
50
wow that weight
actually made quite a bit of difference. i also received my manual today and found i had some breather hose routed wrong :think:
it seems quite a bit nicer. i definantly recomend the flywheel weight.....
new tires, better grips and some bark busters, and im good to go :laugh:
still under 1400, yup bought in a box. literaly.
2-Strokes 4-ever
1,842
4
Missouri
Suzuki is known for not running much flywheel effect on their RM's. Starting in 03 though, they started going with more weight. I put a 12oz on my 03, ride real tight rocky stuff and still wasn't satisfied. Woods cylinder work was the fix, it enhances low-end torque and allows you to ride a gear high........so I'm not constantly chasing the rear end around, but still way fast with a little clutch. Use your clutch a lot and try to stay low in the RPMs.
2wheels
31
Have Eric Gorr port it for low end. It should cost less than an after market pipe. I had my 2002 CR 250 done and now you can hardly stall it it has so much low end.
2-Strokes 4-ever
1,842
4
Missouri
kamchuka said:
for that part you mentioned? i would like to check it out.
Heard from many on this site that are more than pleased with Gorr's work...........Had Varner Motorsport's do mine before I knew of him.
kamchuka
50
sweet i'll check it out!
like to see this bike hang around, i change bikes alot, but this seems good. just gotta get this power under control :yikes:
FRESH VIDEO
